[gdal-dev] Fast Pixel Access
Brian Case
rush at winkey.org
Mon Feb 3 09:26:12 PST 2014
-Jukka
tileindex, mapserver, and the gdal wms driver
On Mon, 2014-02-03 at 17:20 +0000, Jukka Rahkonen wrote:
> Luke Roth <roth.luke <at> gmail.com> writes:
> > Another thing that might speed up access is setting the config
> option GDAL_DISABLE_READDIR_ON_OPEN = TRUE, either as an environment
> variable or on the command line. That should help with GDAL reading the
> directory each time it opens a dataset. I have an application which reads
> one value from each of a large number of datasets and setting this option
> made it run about 3 times faster.
> Hi,
> You are right. This config option makes GDAL to skip the reading of the
> remote directory and saves a lot of bandwidth:
> VRT case:
> Bytes Received: 4 244 509 (of which the vrt file: 4 192 577)
> Sequence (clock) duration: 00:00:09.9996000
> Was:
> Bytes Received: 6 459 443
> Sequence (clock) duration: 00:00:37.8130000
> BigTIFF case:
> Bytes Received: 2 158 917
> Sequence (clock) duration: 00:00:04.4368000
> Was:
> Bytes Received: 4 374 137
> Sequence (clock) duration: 00:00:30.9192000
> Conclusion:
> Both options are unsuitable for serious use while amusing to play with.
> Reading the BigTIFF tile offset index (or whatever it is) seems to mean
> about 2 MB of compultory payload traffic. Reading the VRT file means in this
> example 4 MB of payload. If this sort of net access to a large directory of
> raster files should be important for someone there should be a way to find
> the right raster file and righ data range in that file with minimum amount
> of bytes. Perhaps some kind of rtree indexed vrt file? First aid might be to
> keep the vrt file on the client side.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
