[gdal-dev] Problems linking 1.10 with CURL support
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Mon Feb 3 09:29:20 PST 2014
Andy Cheetham <andy.cheetham <at> geomaticSolutions.com> writes:
> Hi All
> I'm have trouble linking GDAL 1.10 with CURL support enabled.
> I can and have been building GDAL 1.9 with CURL so I'm sure I have all the
> settings within the nmake.opt file correct, unless I have to do something
> different for the latest version.
> I'm on Windows 7 and have tried using both VS2005 and VS2010.
If the ready made Windows builds in http://gisinternals.com/sdk/ do not suit
you perhaps the buildlogs can still help you.
-Jukka Rahkonen-
