[gdal-dev] [GDAL-dev] convert rgba alpha layer to rgb white
Pierre CARREAUD
pierre.carreaud at sites.fr
Wed Feb 5 09:19:31 PST 2014
Hi list,
Im trying to assembly some RGBA tiff in one with gdalbuildvrt and then to
translate them to a RGB TIFF tiled file YCBCR jpeg compressed.
No problem
But now, I would like to get a white color in the background
instead of the black.
The following commands work but I get nodata (and so, black) on any white
pixels whereas I just wanted to convert alpha to white
The problem in on
the vrt.
gdalbuildvrt assembly.vrt -srcnodata b4 hidenodata -vrtnodata 255 *.tif
gdal_translate -of GTIFF -b 1 -b 2 -b 3 -co COMPRESS=JPEG -co
JPEG_QUALITY=95 -co TFW=YES -co BIGTIFF=YES -co ALPHA=NO -co TILED=YES -co
PHOTOMETRIC=YCBCR -co PROFILE=BASELINE assembly.vrt assembly_JPG.tif
gdaladdo -r gauss -ro --config COMPRESS_OVERVIEW JPEG --config
JPEG_QUALITY_OVERVIEW 95 --config BIGTIFF_OVERVIEW YES --config
PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL --config
NODATA_VALUES 255 assembly_JPG.tif 2 4 8 16 32 64 128 256
Do you have an idea? The problem is the is not init option, just -vrtnodata
255 255 255 to fix both background color but also the nodata bandper band
Pierre CARREAUD
Spécialiste en imagerie numérique
carte_voeux_2014
LINGÉNIERIE DE LA DURABILITÉ
SITES Entité Île-de-France
Division du Développement Technique
2 bis avenue du Centre
92500 Rueil-Malmaison, France
Tel : 01 41 39 02 00 / Fax : 01 41 39 02 01
<http://www.sites.fr/> www.sites.fr
CARRES EXPERTISE cid:image002.jpg at 01CB7A74.CDE1E680 INSTRUMENTATION /
MESURES cid:image002.jpg at 01CB7A74.CDE1E680 INGENIERIE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140205/44da2e8f/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140205/44da2e8f/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140205/44da2e8f/attachment-0001.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140205/44da2e8f/attachment-0002.jpg>
