[gdal-dev] how to create just the msk file from a rgba vrt file
Duarte Carreira DCarreira at edia.pt
Fri Feb 7 01:55:06 PST 2014
Thanks Brian.
But this way you rewrite the whole image to disk. It uses lots of disk space and takes forever.
I want to avoid that and just get the mask out to a msk file as fast as possible.
I don't want to convert my rgba vrt mosaic.
The final objective is to get a msk file I can use with the simple rgb vrt mosaic. Then I'll be able to build overviews with jpeg/ycbcr compression which I can't do with rgba vrt because of the 4 bands.
For now I have tried 3 ways:
1) use gdal_rasterize to create a mask directly from the mask polygon shapefile. Then just edit the rgb vrt mosaic and add a  maskband to it. The problem here is gdaladdo does not honor the maskband. This is the fastest way I know, pitty it doesn't work in the end.
2) use gdal_translate like you suggested but use -scale to write all 0s in all 3 bands, and compress with deflate. You get a valid mask and a very, very small useless mosaic. This works but takes a while still.
3) use gdal_translate like you suggested but exaggerate the jpeg compression so it errors out (jpeg_quality=15). You get an invalid 1kb mosaic and an apparently good msk. But it's corrupted in some way. So doesn't work.
I think #1 has potential. If there was a way to somehow turn the tif created by gdal_rasterize into a "true" mask file and have it honored by gdaladdo we would have a winner.
Maybe there's a way to directly export the alpha band from the rgba vrt mosaic to a mks file without writing anything else? That I guess would be the fastest way of all.
Duarte
-----Mensagem original-----
De: Brian Case [mailto:rush at winkey.org]
Enviada: quinta-feira, 6 de Fevereiro de 2014 21:51
Para: Duarte Carreira
Cc: gdal-dev at lists.osgeo.org
Assunto: Re: [gdal-dev] how to create just the msk file from a rgba vrt file
Duarte
gdaltranslate -of outfrmt -b 1 -b 2 -b 3 -mask 4 infile outfile
brian
you can output to vrt's
just dont try to mosaic masked or aphad files with vrts
brian
On Thu, 2014-02-06 at 13:20 +0000, Duarte Carreira wrote:
> Hi there.
> Continuing with trying to cut processing times, I am trying to get a
> msk file from a vrt mosaic, without converting the entire vrt to tif
> just to get the msk file.
> In other words, how can we create a msk file from the alpha band
> without rewriting the whole image?
> Thanks again.
> Duarte
> Duarte Carreira
> Diretor | Dep. Informação Geográfica e Cartografia
> www.edia.pt
> www.alqueva.com.pt
> Tel. +351 284315100
> gdal-dev mailing list
