[gdal-dev] [RFC] [GDAL] Idea for GSoC, 2014
Tim Keitt
tkeitt at utexas.edu
Fri Feb 7 09:20:11 PST 2014
On Fri, Feb 7, 2014 at 11:10 AM, Kshitij Kansal <kansal.k at gmail.com> wrote:
> This means that the final product as a result of this product will also be
> bounded by the above licences. It can not go into GDAL's main distribution
> but can be used as a separate utility of GDAL for non-commercial uses only.
> Basically the commercial use of the tool won't be allowed without approval
> from the concerned people.
> Your views and suggestions are highly appreciated.
That's a no go as far as GSOC is concerned. (I assume this is the
question.) My recollection is that they will not accept a project that is
not released under an approved license.
THK
http://www.keittlab.org/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140207/4d15065b/attachment.html>
