[gdal-dev] gdalwarp EPSG:32662 problem
Jean-Claude Repetto jrepetto at free.fr
Fri Feb 7 23:55:17 PST 2014
On 08/02/2014 07:11, Stephen Woodbridge wrote:
> I've run into a problem that I think is related to a change in the EPSG
> definition for EPSG:32662
> The symptom is that the image after gdalwarp reprojection is about 20km
> south of where it should be.
Please post the gdalwarp command you have used. (I mean, with both CRS).
The problem is likely on the other CRS.
