[gdal-dev] How to exploit the spatial index (*.qix) file for spatial filtering?
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Feb 13 21:39:05 PST 2014
Chuiqing,
You can create an index through SQL. This is the preferred method even if
you stick to the shapefile format for your vector data.
OGRDataSource::ExecuteSQL()
OGR's Shapefile driver supports these SQL commands among others:
CREATE SPATIAL INDEX ON layer_name [DEPTH n]
DROP SPATIAL INDEX ON layer_name
REPACK layer_name
RECOMPUTE EXTENT ON layer_name
On Fri, Feb 14, 2014 at 10:56 AM, C. Zeng <chqzeng at gmail.com> wrote:
> Hi Chaitanya,
> Thank you for your response,
> I know I can do this through GDAL binary, and my question is: how can I
> integrate this function into my code?
> I have a platform like QGIS, I would like the program itself have the
> ability to create and load .qix file. For example, when I open the .shp
> file, I can detect whether there is .qix, if not then create a new qix file;
> When the user zoom the map window, it will filter the map content via the
> qix file to accelerate the searching.
> Does GDAL/OGR has similar functions/classes, something like
> OGRSFDriverRegistrar::Createqix(savepath),
> OGRSFDriverRegistrar::Loadqix(path),to open and use qix files?
> Thank you,
> Chuiqing,
> On Thu, Feb 13, 2014 at 11:46 PM, Chaitanya kumar CH <
> chaitanya.ch at gmail.com> wrote:
>> Chuiqing,
>> The OGR Shapefile driver supports spatial indexing through qix files. To
>> explicitly create a spatial index use the Create Index command:
>> CREATE SPATIAL INDEX ON tablename [DEPTH N]
>> Depth can range from 1 to 12. You can issue the SQL command using ogrinfo.
>> ogrinfo -sql 'CREATE SPATIAL INDEX ON shapefilename [DEPTH N]' path/to/shapefile/directory
>> http://www.gdal.org/ogr/drv_shapefile.html -> Spatial and Attribute Indexing.
>> On Fri, Feb 14, 2014 at 3:12 AM, <chqzeng at gmail.com> wrote:
>>> Hi chaitanya_ch,
>>> I know you are an expert on this, I want to know how can I use GDAL
>>> library to implemented qix reading and using in spatial filtering.
>>> I have many large shape files in Gigbyte level, they are very slow when
>>> navigating in my app. I want to use *.qix file through GDAL library to
>>> accelerate it.
>>> How can I do that?
>>> Thank  you,
>>> C. Zeng
>>> _____________________________________
>>> Sent from http://osgeo-org.1560.x6.nabble.com
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140214/5de8d651/attachment.html>
