[gdal-dev] Gdal_translate won't crop VRT-file
Siebe Bosch siebe at hydroconsult.nl
Fri Feb 14 01:37:00 PST 2014
Dear Joost,
Yes, the extents are as follows:
upper left: 136000, 541250
lower right: 198000, 473750
So as you can see, my crop extent falls within the boundaries of the VRT
file
Kind regards,
Siebe
On 13-02-14 16:49, Andre Joost wrote:
> Am 13.02.2014 12:31, schrieb Siebe Bosch:
>> Any ideas?
> Can you add what gdalinfo reports as extent of your vrt file?
> Greetings,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hydroconsult
Lulofsstraat 55, unit 47
2521 AL Den Haag
The Netherlands
web: http://www.hydroconsult.nl
e-mail: siebe at hydroconsult.nl
phone: +31(0)70 250 0580
mobile: +31(0)6 17 682 689
Aangesloten bij WaterFocus, de coöperatie van
zelfstandige professionals in het waterbeheer
