[gdal-dev] GeoPackage fails after touching it with	Spatialite-gui
    a.furieri at lqt.it
    a.furieri at lqt.it
    Mon Feb 17 07:47:21 PST 2014
On Mon, 17 Feb 2014 16:14:39 +0100, Even Rouault wrote:
> Jukka,
> I highly suspect that the ALTER TABLE must imply a rewriting of the
> file by
> spatialite/spatialite-gui, and when doing so, it doesn't preserve the
> "application id" (4 bytes in the header of sqlite file), that
> geopackage
> specification mentions to be set to a particular value. Consequently
> the
> geopackage driver later fails when checking the signature.
the current version of spatialite-gui doesn't offerts any support to
GPKG;
Brad Hards has recently added few GPKG oriented-APIs into
libspatialite-4.2.0-devel,
but this only affects the library.
the GUI-tool itself *always* assumes it's processing a genuine
spatialite
DB-file.
>> I could do a few things with Spatialite-gui without troubles: create
>> a view,
>> create an index, add column. But then I renamed one table and after
>> that I
>> cannot use the DB file with GPKG driver any more.
Jukka,
if you had actually invoked the user friendly dialog box "rename table"
it's not at all surprising discovering that you've simply introduced
some fatal corruption in your DB
the spatialite_gui tool is strictly intended to support "genuine
SpatiaLite
DB-files"; I strongly fear that any attempt to use this highly
specialized
tool on behalf of some GPKG-file would simply end in disasters.
some future version of the GUI tool will surely implement some kind of
GPKG support: but for now using the current version on any GPKG-file
surely is a risky and unsafe business.
bye Sandro
