[gdal-dev] GeoPackage fails after touching it with Spatialite-gui
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Tue Feb 18 05:03:46 PST 2014
Pepijn Van Eeckhoudt <pepijn <at> vaneeckhoudt.net> writes:
> Apolgies up-front for the self promotion...
> Jukka,
> If you need a basic geopackage enabled sqlite shell, you can compile
> https://bitbucket.org/luciad/libgpkg to get this. One of the outputs is
> the 'gpkg' binary which is the sqlite shell with the libgpkg extension
> preloaded. This is nowhere near as featureful as ogr or spatialite, but
> should already allow you to do basic CLI geopackage management.
Hi Pepijn,
If you knew me and wanted me to play with your toy (that I for sure would
like to do) you would have compiled Windows binaries for downloading.
Compile is not what I do, I merely test and complain :)
-Jukka-
> Regards,
> Pepijn
