[gdal-dev] Is there documetation about filters and some python utilities?
Simon Shak skunkmyrddyn at gmail.com
Tue Feb 18 14:11:28 PST 2014
I perform similar tasks. While there are probably some internal methods
inside python, I make calls to ImageMagick to perform the image
manipulation. I first write a baseline tiff with the tfw with
gdal_translate then preform convert commands to do the image processing
then gdal_translate again to turn the baseline tiff and tfw back into a
geotiff.
On Feb 16, 2014 5:36 AM, "Jukka Rahkonen" <jukka.rahkonen at mmmtike.fi> wrote:
> Hi,
> I was thinking that a possibility to run images through filters with GDAL
> could be nice sometimes. Especially for visual work with aerial and
> satellite images filters like "sharpen" of "unsharp mask"
> http://en.wikipedia.org/wiki/Unsharp_masking are often very useful. But
> then
> I found that kernel filters can already be used inside VRT files. Are there
> usage examples with before-after comparison images somewhere in our
> documentation?
> I also found that there are some python scripts included in
> \gdal\bin\gdal\python\scripts at least in the gisinternals GDAL builds but
> some scripts are not listed in http://gdal.org/gdal_utilities.html.  Is
> there some other place where to find documentation about these scripts, for
> example gdal_calc.py ? Some other than the sources, I mean.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140218/f0c32fe6/attachment.html>
