[gdal-dev] Building GDAL with Kakadu
Even Rouault
even.rouault at mines-paris.org
Thu Feb 20 05:52:01 PST 2014
Joseph,
The kakadu executable is not sufficient. You need to buy a licence that will
give you the SDK necessary to build GDAL against Kakadu. If you can't afford
that, you may consider the JP2OpenJPEG driver based on the free library OpenJPEG
: http://gdal.org/frmt_jp2openjpeg.html
> Hello all,
> I am getting following error during building the GDAL with kakadu.
> *jp2kakdataset.cpp:34:23: fatal error: jp2_local.h: No such file or
> directory*
> *compilation terminated.*
> *make[2]: *** [../o/jp2kakdataset.lo] Error 1*
> *make[2]: Leaving directory
> `/home/naveen/Downloads/gdal-1.10.1/frmts/jp2kak'*
> *make[1]: *** [jp2kak-install-obj] Error 2*
> *make[1]: Leaving directory `/home/naveen/Downloads/gdal-1.10.1/frmts'*
> *make: *** [frmts-target] Error 2*
> I only kakadu executable at
kakadusoftware.com/<http://www.kakadusoftware.com/index.php?option=com_content&task=view&id=26&Itemid=22>
> Can somebody please tell me where to get source code of kakadu.
> so I can build it properly.
> or If there exits another solution of this problem please let me know.
> Joseph Jack
