[gdal-dev] Help with color map for raster grid
Chaitanya kumar CH
chaitanya.ch at gmail.com
Mon Feb 24 21:00:45 PST 2014
Daniel,
You can make changes in two places. In the data or the display engine. In
the data, you can modify the colour table. This will be permanent. In the
display, you just load a different color table based on the table of pixel
values. If you don't like either, you can build a gdal vrt file and modify
its colour table.
http://www.gdal.org/gdalbuildvrt.html
http://www.gdal.org/gdal_vrttut.html
Best regards,
Chaitanya Kumar CH
On 25-Feb-2014 9:26 am, "windchaser" <dkaminski at gmail.com> wrote:
> Hi,
> I am working with GDAL in a C# project. I need help figuring out how to
> increase the colors displayed on a raster grid. Opening the file using
> Gdal.Open("myfile", OSGeo.GDAL.Access.GA_ReadOnly); seems to offer some
> colors but I would like to increase the number of colors for the raster
> map,
> specially for floating point raster.
> Here is an example of what i am trying to achieve using GDAL.
> http://screencast.com/t/LPjJ7pTk <http://screencast.com/t/LPjJ7pTk>
> Thanks for your help!
> Daniel
> http://osgeo-org.1560.x6.nabble.com/Help-with-color-map-for-raster-grid-tp5105698.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140225/d54b2d3e/attachment.html>
