[gdal-dev] Layers and features
Even Rouault
even.rouault at mines-paris.org
Wed Feb 26 13:02:22 PST 2014
Tim,
> When I extract a feature from a layer, what issues arise with the lifetime
> of the feature and the layer? If I keep the layer alive, will the feature
> continue to be valid?
Yes, feature objects (at least at C++ objects, not speaking about bindings)
retrieved by GetNextFeature() and GetFeature() are completely free-standing.
You can close the datasource and they should still be valid (reason: they keep
a reference to their feature definition object, and once the last feature has
been destroyed and the datasource closed, the feature definition will be
destroyed)
> If I clone a feature, is it now standalone or does it still depend on the
> layer/datasource in anyway?
No, and you don't need to clone it actually. See above
> I see the note about destroying features prior to deleting the layer but
> need a bit of clarification on the dependencies.
Are you refering to "It is critical that
all features associated with an OGRLayer (more specifically an
OGRFeatureDefn) be deleted before that layer/datasource is deleted." ?
Well, I think the note is wrong actually. Perhaps it dates back to old ages
where the feature definition was not yet ref-counted ??
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
