[gdal-dev] Can not open bigtiff file using gdal1.10 API saved by photoshop cs6
Even Rouault even.rouault at mines-paris.org
Fri Feb 28 05:26:44 PST 2014
Selon ridgewang <ridgewang at gmail.com>:
> Ps, sometimes it creates bigtiff file without any error reports by gdal 1.10
> api, but can not open the tiff file by gdal api and reports zero stripsize.
> anyway, the photoshop cs6 can open the tiff file correctly. for tips that
> the file is created and save in a usb mobile harddisk. I wonder why the
> photoshop so robust can open the tifffile with a zero stripsize?l
Could you add in the ticket details about your GDAL build : OS, 32/64 bit build,
use of internal libtiff or external libtiff (in the later case, which version).
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-not-open-bigtiff-file-using-gdal1-10-API-saved-by-photoshop-cs6-tp5105979p5106514.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
