[gdal-dev] SetAttributeFilter and OSM
Even Rouault even.rouault at mines-paris.org
Sat Jan 4 09:14:12 PST 2014
Arno,
Do you replicate that with ogrinfo with the -where option ?
Could you show us how you do this with a code snippet and the filter you've used
Even
> Hello,
> I'm using the GDAL/OGR libraries in a C# application and I have some trouble
> with the SetAttributeFilter function on an OGR layer.
> The filtering works fine when I load a SHP file, but when I load an OSM file
> it doesn't work. I still get all the features on the layer. Is this a known
> limitation of the OSM reader or did I make a mistake somehow?
> Thanks,
> Arno
> http://osgeo-org.1560.x6.nabble.com/SetAttributeFilter-and-OSM-tp5096352.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
