[gdal-dev] Convert GeoPDF with gdal_translate
Even Rouault even.rouault at mines-paris.org
Tue Jan 7 13:02:24 PST 2014
Le mardi 07 janvier 2014 20:51:32, Pekka Sarkola a écrit :
> Hi!
> Maybe newbie problem. I download GeoPDF file from
> http://lib.utexas.edu/maps/topo/nicaragua/ and try to get information with
> gdalinfo and translate with gdal_translate.
> Both command response: "ERROR 4: `argelia-nicaragua-50k-3154iii-1981.pdf'
> not recognised as a supported file format."
> GDAL version 1.10.1, both on Windows and Ubuntu. gdalinfo -formats
> recognize PDF-format as supported.
> Is this on my installation or somewhere in gdal?
Not exactly your installation, but the build you've picked up. I've verified
this is a valid geospatial PDF file recognized by the GDAL PDF driver.
I assume your GDAL build has only write support for geospatial PDF (which
doesn't require any third-party library), but not read support that requires
linking to a third-party library, like Poppler or Podofo. Unfortunately
gdalinfo --formats can only report read/write support even when it's write-
only.
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
>  <mailto:pekka.sarkola at gispo.fi> pekka.sarkola at gispo.fi   - GSM +358 40 725
> 2042
>  <http://www.gispo.fi> www.gispo.fi -  <http://www.paikkatieto.com>
> www.paikkatieto.com
Geospatial professional services
http://even.rouault.free.fr/services.html
