[gdal-dev] Ogr2ogr does not support file name with non-ASCII character
maven apache
apachemaven0 at gmail.com
Tue Jan 7 16:03:23 PST 2014
Hi:
This is a cross post first post at
http://gis.stackexchange.com/questions/82142/ogr2ogr-does-not-support-file-name-with-non-ascii-character
Since I got no answer, then I think I may post it here, this is the
original question:
I tried to use the following script to convert shapefile to mif:
ogr2ogr -f "MapInfo File" D:\docs\arcgis_data\shp_mif\BOU.mif
D:\docs\arcgis_data\shp\BOU.shp
it works.
But I found that if the name of the shapefile has non-ASCII characters like
this:
D:\docs\arcgis_data\shp\臺北.shp
Then the covert will fail with message:
Unable to open datasource `D:\docs\arcgis_data\shp\臺北.shp' with the
following drivers
Any idea to fix it?
Looking for replay.
Yang
2014.1.8
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140108/771e5f51/attachment-0001.html>
