[gdal-dev] Ogr2ogr does not support file name with non-ASCII character
Dmitriy Baryshnikov bishop.dev at gmail.com
Wed Jan 8 22:28:59 PST 2014
You shouldn't know that file name is UTF. It maybe not in UTF (e.g. in
you system encoding - in Linux usually UTF-8,  in Windows - CP1252,
CP1251 etc.).
But you command line shell (bash, cmd, etc.) should encode the input to
the UTF8, or you have to set the environment variable
GDAL_FILENAME_IS_UTF8 to NO.
Best regards,
     Dmitry
09.01.2014 4:00, maven apache ?????:
> Hi:
> Thanks for your reply.
> But I wonder how do I know if the file name is utf8? Since not all of
> the filename contain no-asci characters.
> Thanks
> 2014/1/8 Dmitriy Baryshnikov <bishop.dev at gmail.com
> <mailto:bishop.dev at gmail.com>>
>     Hi,
>     The GDAL utilities expected all input paths in UTF-8 encoding. If
>     you want to use system native encoding you have to set
>     GDAL_FILENAME_IS_UTF8 environment variable to NO.
>     http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_FILENAME_IS_UTF8
>     Best regards,
>          Dmitry
>     08.01.2014 4:03, maven apache ?????:
>>     Hi:
>>     This is a cross post first post at
>>     http://gis.stackexchange.com/questions/82142/ogr2ogr-does-not-support-file-name-with-non-ascii-character
>>     Since I got no answer, then I think I may post it here, this is
>>     the original question:
>>     I tried to use the following script to convert shapefile to mif:
>>     |ogr2ogr -f "MapInfo File" D:\docs\arcgis_data\shp_mif\BOU.mif D:\docs\arcgis_data\shp\BOU.shp
>>     it works.
>>     But I found that if the name of the shapefile has non-ASCII
>>     characters like this:
>>     |D:\docs\arcgis_data\shp\??.shp
>>     Then the covert will fail with message:
>>     |Unable to open datasource `D:\docs\arcgis_data\shp\??.shp' with the following drivers
>>     Any idea to fix it?
>>     Looking for replay.
>>     Yang
>>     2014.1.8
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140109/ed871356/attachment.html>
