[gdal-dev] gdal_clip
Zachary L. Stauber
zachary at stauber.org
Thu Jan 9 07:39:35 PST 2014
Replying to all respondents on this thread... M. Rouault's right, it
appears to duplicate the functionality of gdal_rasterize with the -burn
option, which I had never looked into. Thus, I withdraw the idea. If
anyone wants a copy of the source or a compiled executable, I will still
provide that. And thank you M. Rouault for providing the functionality.
-Zack
On Jan 9 2014 5:04 AM, Even Rouault wrote:
> Zachary,
> is it different from gdal_rasterize with the burn option ?
> Even
>> Dear developers,
>> I would like to contribute some code to the project. I have a
>> utility I call gdal_clip I wrote wrote in C++, which I used to
>> compile
>> against the FWTools gdal .lib file and later Mr. Szekeres .lib
>> files,
>> which will "clip" an image. It uses an input image and an input
>> polygon
>> shapefile, and where the polygons in the shapefile overlap the
>> image, it
>> will fill them in with a chosen color (defaults to black). It will
>> NOT
>> resize the output image in any way.
>> This was useful for me to black out, or white out areas of
>> tiles
>> in orthophoto projects that were outside the project boundary
>> (outside
>> of control network and therefore of low accuracy). I am out of the
>> photogrammetry business, but I have photogrammetry colleagues who
>> wish
>> for me to recompile this every time there is a new set of builds on
>> gisinternals.com/sdk, so it may be useful to build it into GDAL's
>> code.
>> It is pretty optimized, not doing a pixel-in-polygon check for
>> EVERY pixel, but breaking the image into tiles and then breaking
>> those
>> tiles into quarters only if they intersect the polygons, and so
>> forth
>> down to individual pixels. It works correctly with doughnut
>> polygons
>> and rotated images. I probably need to pretty up the code in some
>> way
>> friendly to Doxygen, but otherwise it is ready to go.
>> In the future I'd like to generalize the code to deal with
>> polygons from any vector data source that OGR reads, and optionally
>> resize an image to cut it down if large parts are clipped. It would
>> also be nice to make it smart enough to reproject the input polygons
>> to
>> the image's coordinate reference system if they are not the same. I
>> also think right now it only reads in and outputs TIFF images. But
>> again, I think it is useful right now. Please let me know if you
>> all
>> think this would be useful or would like the code to see.
>> It is all MIT license right now, but could be changed to
>> GDAL's
>> standard license if necessary.
>> -Zack Stauber
>> Albuquerque, New Mexico
>> United States
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
