[gdal-dev] Standard Dev. Environment?
Jay L. jlaura at asu.edu
Fri Jan 10 11:44:03 PST 2014
Have you also seen the geobox environment?
https://github.com/zhm/geobox
The install fails as the links to postgres configs are outdated (GiST URL
changes)  Alan, if you have no issue, I might fork geobox and swap in your
PostGreSQL lines to get geobox back up and running.  I think it is easier
to share with beginning users that the OSGEO live CD.
On Fri, Jan 10, 2014 at 11:41 AM, Alan Boudreault
<aboudreault at mapgears.com>wrote:
>  The github: https://github.com/aboudreault/mapserver_dev-cookbook
> Note that I started to upgrade the environment to be compatible with the
> latest vagrant. I will also update the README file in the repo since the
> procedure will be easier (since a few things I was using have been directly
> integrated as vagrant plugin).
> I plan to finish this during the next week.
> Alan
> On 14-01-10 01:36 PM, Daniel Morissette wrote:
> On 14-01-10 1:23 PM, Jay L. wrote:
> Success.  Ivan, I used your ./configure flags - stock was also not
> working on this VM.
> I wonder if the dev. community is large enough to warrant storing a
> lightweight Vagrant box image somewhere.
> Talking of Vagrant, FYI about a year ago Alan Boudreault wrote a set of
> Vagrant and Chef recipes to automate the setup of a MapServer dev
> environment (which includes GDAL as a dependency). The recipes are a bit
> old already, but it may be a good starting point for automating the setup
> of a GDAL dev environment.
> If you're interested, see:
> http://www.alanb.ca/blog/2013/03/09/setup-a-mapserver-development-environment-with-vagrant-and-chef/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/124e1064/attachment.html>
