[gdal-dev] GDAL Docker image
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed Jan 15 03:07:45 PST 2014
In case it's of use to anyone else, I've uploaded an image to the docker
index containing a recent build of GDAL (see
https://index.docker.io/u/homme/gdal/ for details).
The only dependency is that you have docker installed
(http://www.docker.io/ - currently only on x86_64). Assuming that, the
following command will open a bash shell in an Ubuntu based environment
with GDAL available:|
|docker run -t -i homme/gdal:latest /bin/bash
The build process closely follows that defined in
<https://github.com/OSGeo/gdal/blob/trunk/.travis.yml> but omits Java
support. `configure` outputs the following:
GDAL is now configured for x86_64-unknown-linux-gnu
Installation directory: /usr/local
C compiler: gcc -fPIC -g -DDEBUG
-DHAVE_SSE_AT_COMPILE_TIME
C++ compiler: g++ -fPIC -g -DDEBUG
LIBTOOL support: no
LIBZ support: external
LIBLZMA support: yes
GRASS support: no
CFITSIO support: no
PCRaster support: internal
LIBPNG support: external
DDS support: no
GTA support: yes
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: external
12 bit JPEG: yes
12 bit JPEG-in-TIFF: no
LIBGIF support: external
OGDI support: no
HDF4 support: yes
HDF5 support: yes
NetCDF support: yes
Kakadu support: no
JasPer support: no
OpenJPEG support: yes
ECW support: yes
MrSID support: yes
MrSID/MG4 Lidar support: yes
MSG support: no
GRIB support: yes
EPSILON support: yes
WebP support: yes
cURL support (wms/wcs/...):yes
PostgreSQL support: yes
MySQL support: no
Ingres support: no
Xerces-C support: yes
NAS support: yes
Expat support: yes
libxml2 support: yes
Google libkml support: yes
ODBC support: yes
PGeo support: yes
FGDB support: yes
MDB support: no
PCIDSK support: internal
OCI support: no
GEORASTER support: no
SDE support: no
Rasdaman support: no
DODS support: no
SQLite support: yes
PCRE support: yes
SpatiaLite support: yes
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: yes
Poppler support: yes
Podofo support: yes
OpenCL support: no
Armadillo support: no
FreeXL support: yes
SOSI support: no
SWIG Bindings: python
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: yes
enable POSIX iconv support:yes
hide internal symbols: no
Improvements/suggestions are very welcome!
Best regards,
Homme
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140115/eb1652d4/attachment.html>
