[gdal-dev] Problem calling gdalwarp from within python script
Simon Richard Proud srp at geo.ku.dk
Sun Jan 19 15:00:55 PST 2014
Hi, thanks for the reply.
I tried changing the call to this:
process.call(["gdalwarp","-q","-multi","-r cubicspline","-t_srs '+proj=geos +lon_0=0.0 +h=35785831'","-te -5568748.2758 -5568748.4774 5568748.2758 5568748.2758","-tr 3000.40316582 3000.40316582","-srcnodata 65535","TEST.tiff","TEST2.tiff"])
But still receive just the usage instructions, I can't see any other arguments that can be divided into an element. Setting the "shell=True" option also has no effect.
/Simon
________________________________________
Fra: Kurt Schwehr [schwehr at gmail.com]
Sendt: 19. januar 2014 17:47
Til: Simon Richard Proud
Cc: gdal-dev at lists.osgeo.org dev
Emne: Re: [gdal-dev] Problem calling gdalwarp from within python script
try
> subprocess.call(["gdalwarp", "-q",  "-multi",   ...   "TEST2.tiff"])
Each arg must be an element in the list.
-kurt
On Jan 19, 2014, at 2:27 PM, Simon Proud <srp at geo.ku.dk> wrote:
> Hi,
> I wish to call gdalwarp from within a python script but I cannot get it to
> work.
> The command I wish to run is:
> gdalwarp -q -multi -r cubicspline -t_srs '+proj=geos +lon_0=0.0 +h=35785831'
> -te -5568748.2758 -5568748.4774 5568748.2758 5568748.2758 -tr 3000.40316582
> 3000.40316582 -srcnodata 65535 TEST.tiff TEST2.tiff
> I'm running on Ubuntu 12.04. The above command works perfectly when called
> from a terminal window and produces a good output image.
> But when I run from python I get problems.
> First, I tried to run with subprocess.call(["gdalwarp","-q -multi ...
> TEST2.tiff"]) then all I see is the default usage instructions. No file is
> created. Same if I use popen.
> If I use: os.system("gdalwarp -q -multi ... TEST2.tiff") then it does run
> and I see the expected text on the screen. However, in this case the output
> file is blank - it is the right size and contains the right georeferencing
> information but every pixel in the image has a value of zero.
> Does anyone have an idea what could be the problem here?
> Thanks!
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-calling-gdalwarp-from-within-python-script-tp5098902.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
