[gdal-dev] Problem calling gdalwarp from within python script
Pietro Zambelli
peter.zamb at gmail.com
Mon Jan 20 01:40:17 PST 2014
On Sunday 19 Jan 2014 14:27:49 Simon Proud wrote:
> Hi,
> I wish to call gdalwarp from within a python script but I cannot get
> it to work.
> The command I wish to run is:
> gdalwarp -q -multi -r cubicspline -t_srs '+proj=geos +lon_0=0.0
> +h=35785831' -te -5568748.2758 -5568748.4774 5568748.2758
> 5568748.2758 -tr 3000.40316582 3000.40316582 -srcnodata 65535
> TEST.tiff TEST2.tiff
You can run the command directly with:
cmd = "gdalwarp -q -multi -r cubicspline -t_srs '+proj=geos +lon_0=0.0
TEST.tiff TEST2.tiff"
Subprocess.Popen(cmd, shell=True)
See the doc:
http://docs.python.org/2/library/subprocess.html#using-the-subprocess-module
Pietro
