[gdal-dev] gdaldem slope with -s 111120.0 works only at equator for lat/lon?
John Abraham
jea at hbaspecto.com
Wed Jan 22 14:14:01 PST 2014
Please help me with something potentially important. The documentation for gdaldem slope says “If the horizontal unit of the source DEM is degrees (e.g Lat/Long WGS84 projection), you can use scale=111120 if the vertical units are meters” but I don’t think this works very far away from the equator. I think the algorithm assumes that the north-south units are the same as the east-west units, whereas obviously away from the equator degrees of longitude become a lot shorter.
I’m looking at my attempt at avalanche slope mapping, and seem to see east-west slopes showing up with higher slopes than north-south slopes with identically spaced contour intervals.
Am I right? Or am I seeing things?
If I’m right, perhaps:
1) Someone should fix the documentation, so that people don’t rely on incorrect slope calculations for something life-critical such as avalanche slope mapping, and
2) Someone could tell me a better solution, I think perhaps the best idea is to just resample the grid into a projection based on meters, before applying gdaldem without any scaling factor.
Thanks for your help. This has been bugging me for sometime, but I finally decided to speak up.
John Abraham
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140122/81c33018/attachment-0001.html>
