[gdal-dev] Extra Decimal places added to ASCII gdal_translate mosaic
Norman Vine
nhv at cape.com
Fri Jan 24 07:11:50 PST 2014
try
> gdal_translate -of AAIGrid -co DECIMAL_PRECISION=3 abc.vrt abc.asc
see http://www.gdal.org/frmt_various.html
HTH
Norman
On Jan 24, 2014, at 10:01 AM, Jonathan Moules <jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
> I'm trying to mosaic some ASCII grid tiles into a single large ASCII file (which can then easily be handled).
> I'm using this process:
> REM Create list of files
> dir /b /s *.asc > asc_list.txt
> REM Turn into VRT
> gdalbuildvrt -srcnodata "-9999" -vrtnodata "0" -a_srs "EPSG:27700" -input_file_list "asc_list.txt" abc.vrt
> REM actual mosaicing
> gdal_translate -of AAIGrid abc.vrt abc.asc
> The input files are like:
> ncols 500
> nrows 500
> xllcorner 432000.000
> yllcorner 243000.000
> cellsize 2
> nodata_value -9999.0
> 98.354 98.449 98.658 98.874 99.038 99.096
> But the outputs are like:
> fncols 500
> nrows 1000
> xllcorner 432000.000000000000
> yllcorner 242000.000000000000
> cellsize 2.000000000000
> NODATA_value 0
> 98.353996276855469 98.448997497558594 98.657997131347656 98.874000549316406
> Suddenly everything has a dozen extra decimal places. Not only does this induce the False Precision problem (we don't have heights to the femtometer!), it also massively increases the filesize.
> How can I get this to not happen?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation._______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140124/baed0756/attachment.html>
