[gdal-dev] gdaldem slope with -s 111120.0 works only at equator for lat/lon?
John Abraham jea at hbaspecto.com
Fri Jan 24 15:47:45 PST 2014
Here’s a diff on the .dox for gdaldem, as a suggestion.  (I don’t want commit access on the repository.  Is sending the diff by email the appropriate approach?)
Note I’m assuming that the other modules in gdaldem also assume that x and y units are the same.
Index: gdal_utilities.dox
--- gdal_utilities.dox	(revision 26875)
+++ gdal_utilities.dox	(working copy)
@@ -2038,8 +2038,14 @@
                 [-compute_edges] [-b Band (default=1)] [-of format] [-q]
 Notes :
-  Scale is the ratio of vertical units to horizontal
-   for Feet:Latlong use scale=370400, for Meters:LatLong use scale=111120)
+  gdaldem generally assumes that x, y and z units are identical.  If x (east-west)
+  and y (north-south) units are identical, but z (elevation) units are different, the
+  scale (-s) option can be used to set the ratio of vertical units to horizontal.  For
+  LatLong projections near the equator, where units of latitude and units of
+  longitude are similar, elevation (z) units can be converted to be compatible
+  by using scale=370400 (if elevation is in feet) or scale=111120 (if elevation is in
+  meters).  For locations not near the equator, it would be best to reproject your
+  grid using gdalwarp before using gdaldem.
 \endverbatim
 \if man
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140124/1e21c8dd/attachment.html>
