[gdal-dev] gdaltranslate and gdalwarp rotating and resizing image without being asked to, why?
Jesse McGraw
jlmcgraw at gmail.com
Wed Jul 2 08:05:07 PDT 2014
Even,
Thank you for the very detailed responses. Time to go do some more
googling on GDAL perl bindings (or dig into python)
On Tue, Jul 1, 2014 at 4:37 PM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Le mardi 01 juillet 2014 15:50:18, Jesse McGraw a écrit :
> > On Mon, Jun 30, 2014 at 3:07 PM, Even Rouault
> > wrote:
> > > That might the problem. If you create the GCPs on the PDF and not on
> the
> > > PNG,
> > > and that the PDF has rotation, pdftoppm I think will apply the
> rotation,
> > > hence
> > > the axis swapping.
> > Remember, I'm using the PNG I've created for all gdal operations, gdal
> > never interacts with the source PDF
> > I'm probably fundamentally misunderstanding some aspect of the command
> > lines I'm using in gdal*. My end goal is to get the necessary affine
> > transformation information to display the PNG I create in step 3a
> properly
> > in a separate Android moving-map application (eg. your current position
> > displayed on the diagram as you move around the airport)
> Jesse,
> hum ok, with the images I think I now understand the situation (I've only
> looked at the landscape diagram) and what you want.
> You probably don't want to use gdalwarp, which by default will result in a
> north-up image. You likely want to compute the geotransform affine matrix
> for
> your GCPs and set it, since indeed your GCPs define a 1st-order
> transformation.
> The GDAL C API has GDALGCPsToGeoTransform() which does exactly this. I see
> it
> is also available in the Python API : gdal.GCPsToGeoTransform().
> See http://svn.osgeo.org/gdal/trunk/autotest/gcore/gcps2geotransform.py
> for
> how to use it.
> You could then just do a CreateCopy() of the PNG to a VRT, and set the
> returned geotransform by the previous step with SetGeoTransform().
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140702/acd79f64/attachment.html>
