[gdal-dev] GeoPDF fails despite poppler/godofo
John W. Glendening
glendening at drjack.net
Wed Jul 2 10:25:35 PDT 2014
Evan
I'm happy to report your confidence was not misplaced. This make was
indeed being run after a previous initial build of PDAL. After now
starting with "make clean", the new gdalinfo successfully recognizes the
GeoPDF. Thanks very much for that insight, which likely saved me many
hours of puzzling and fruitless searching.
And let me take this opportunity to thank the GDAL developers for their
dedication and hard work. Without GDAL I would not have attempted to
create the maps I have for our local hikers, so your work benefits many,
many people in addition to its actual users.
Jack
On Wed, 2014-07-02 at 18:52 +0200, Even Rouault wrote:
> John,
> if you did several attempts of ./configure and intermediate builds, you may
> need to "make clean" before "make; make install". The dependencies rules of
> the GDAL makefiles are rather primitive and don't generally notice in-between
> configuration changes
> The write-side of the PDF driver is only driver, and gdalinfo --formats has no
> way of indicating a write-only driver, so it is possible that the PDF support
> available is write-only despite the rw.
> The content of config.log is OK, so I'm confident that cleaning before
> rebuilding should solve your issue.
> Even
> > I am unable to get a GDAL 1.11.0 build to recognize any GeoPDF I have
> > obtained from the USGS, despite having configured with poppler and
> > podofo, both separately and together. Running
> > usr/local/bin/gdalinfo CA_Rana_Creek_20120306_TM_geo.pdf
> > gives
> > ERROR 4: `CA_Rana_Creek_20120306_TM_geo.pdf' not recognised as a
> > supported file format.
> > Otherwise GDAL utilities seem to run without problems.
> > Output from "/usr/local/bin/gdalinfo --formats" includes "PDF (rw):
> > Geospatial PDF"
> > Details are: Ubuntu 14.04, separately built GDAL 1.11.0
> > after using apt-get to get Ubuntu version of poppler and podofo. (I also
> > installed
> > the Ubuntu version of GDAL, for which /usr/bin/gdalinfo gave the same
> > result.)
> > The config.log (for --with-poppler) includes statements
> > configure:27673: checking for poppler
> > configure:27744: checking if we have Poppler >= 0.20.0
> > configure:27755: checking if we have Poppler >= 0.23.0
> > HAVE_POPPLER='yes'
> > LIBS='-lpoppler -lexpat -lnetcdf -lmfhdfalt -ldfalt -ljpeg -ltiff
> > -lpng -lz -lpthread -lm -lrt -ldl '
> > POPPLER_0_20_OR_LATER='yes'
> > POPPLER_0_23_OR_LATER='yes'
> > POPPLER_BASE_STREAM_HAS_TWO_ARGS='yes'
> > POPPLER_HAS_OPTCONTENT='yes'
> > POPPLER_INC='-I/usr/include -I/usr/include/poppler'
> > I'm at a loss to figure out how to get GDAL to recognize/use the
> > GeoPDFs (my intent is to create GeoTiffs from them using
> > gdal_translate), since on-line search finds that failure to include
> > poppler or podofo is generally the reason for a "ERROR 4" result -
> > but that is not the case here.
> > Jack
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
John W. (Jack) Glendening 831-484-6929
25953 Deer Run Lane Salinas, CA 93908
