[gdal-dev] Range of band value changes when warping
bas smit baspysmit at gmail.com
Wed Jul 9 01:49:34 PDT 2014
When the source image band having pixel values in the range of 52 and 207
is warped using the following command:
gdal_warp -t_srs wgs84 -r near in_file out_file
The resulted band has the pixel values in the range of 0 and 255 How can I
make the range unchanged during warp?
Bas Smit
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140709/ea9d1ffa/attachment.html>
