[gdal-dev] Unable to read PDS3 (img + lbl) Moon DEM
Even Rouault
even.rouault at mines-paris.org
Thu Jul 10 02:51:18 PDT 2014
Selon GrJo <gregor.jochmann at rt.rif-ev.de>:
> I've tried to access a lunar elevation model, but gdalinfo and gdal_translate
> give me a strange error message.
> "Error1: Sample_bits of 0 is not supported in this gdal PDS reader"
> The elevation model is a PDS3 pair (.img with seperate .lbl file), and
> pointing gdalinfo to the lbl file gives me the above error message (pointing
> to the .img directly gives "not a recognized file format"):
> IMG (binary)
<http://imbrium.mit.edu/DATA/LOLA_GDR/CYLINDRICAL/IMG/LDEM_256_00N_90N_000_180.IMG>
> LBL (plaintext label)
<http://imbrium.mit.edu/DATA/LOLA_GDR/CYLINDRICAL/IMG/LDEM_256_00N_90N_000_180.LBL>
> the strange thing is - the label file explicitely specifies says "
> SAMPLE_BITS = 16" in line 52.
> Is this a bug in the reader, an invalid label file or am i doing something
> wrong?
Nothing wrong. You are just using an old version of GDAL. Your issue is
http://trac.osgeo.org/gdal/ticket/3943 that was fixed in GDAL 1.9.0.
http://osgeo-org.1560.x6.nabble.com/Unable-to-read-PDS3-img-lbl-Moon-DEM-tp5150432.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
