[gdal-dev] [BULK] Re: Dissolve shapefile using GDAL/OGR
kalu671
kalu671 at gmail.com
Fri Jul 11 07:21:08 PDT 2014
Hello Dan,
I tried to use the syntax and I am getting the error:
"The filename, directory name, or volume label syntax is incorrect."
my syntax is as below:
inFile = "D:\Dir1\Polygons.shp"
outFile = "D:\Dir2\Dissolved_polygons.shp"
dissolve = 'C:\OSGeo4W64\apps\saga\saga_cmd shapes_polygons "Polygon
Dissolve" -POLYGONS = ' + inFile + ' -DISSOLVED = ' + outFile + ' -FIELD_1=
Value -DISSOLVE= 0'
subprocess.call(dissolve, shell=True)
Would you please suggest what did I do wrong?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Dissolve-shapefile-using-GDAL-OGR-tp5036930p5150675.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
