[gdal-dev] gdal2tiles.py generating dark tiles
Allan Oware
allanoware at gmail.com
Mon Jul 14 00:02:33 PDT 2014
Hi all,
Dark tiles are generated when I run gdal2tiles.py on a .IMG file(a scanned
and georeferenced topographical map).
A sample png of the tiles generated is found here
<https://sites.google.com/site/lumtegis/files/519.png>. Even when i
translate to tiff, the output is still the same. Why does
gdal2tiles.py give this result ?
The gdalinfo output is as below:
Driver: HFA/Erdas Imagine Images (.img)
Files: ALOI.IMG
ALOI.IMG.aux.xml
Size is 3830, 2552
Coordinate System is:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.017453292519943295]]
Origin = (32.999437318839924,3.000470692247897)
Pixel Size = (0.000392066994127,-0.000392066994127)
Metadata:
DataType=Generic
Corner Coordinates:
Upper Left ( 32.9994373, 3.0004707) ( 32d59'57.97"E, 3d 0'1.69"N)
Lower Left ( 32.9994373, 1.9999157) ( 32d59'57.97"E, 1d59'59.70"N)
Upper Right ( 34.5010539, 3.0004707) ( 34d30'3.79"E, 3d 0'1.69"N)
Lower Right ( 34.5010539, 1.9999157) ( 34d30'3.79"E, 1d59'59.70"N)
Center ( 33.7502456, 2.5001932) ( 33d45'0.88"E, 2d30'0.70"N)
Band 1 Block=64x64 Type=UInt16, ColorInterp=Undefined
Description = Layer_1
Min=0.000 Max=255.000
Minimum=0.000, Maximum=255.000, Mean=225.572, StdDev=31.338
NoData Value=256
Overviews: 1915x1276, 958x638, 479x319, 240x160
Metadata:
STATISTICS_COVARIANCES=982.046346716112,845.521289084631,710.510646703791
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=255
STATISTICS_MEAN=225.57242379015
STATISTICS_MEDIAN=0
STATISTICS_MODE=0
STATISTICS_STDDEV=31.337618714831
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
STATISTICS_EXCLUDEDVALUES=
LAYER_TYPE=athematic
Image Structure Metadata:
COMPRESSION=RLE
Band 2 Block=64x64 Type=UInt16, ColorInterp=Undefined
Description = Layer_2
Min=4.000 Max=255.000
Minimum=4.000, Maximum=255.000, Mean=226.079, StdDev=29.739
NoData Value=256
Metadata:
STATISTICS_COVARIANCES=845.521289084631,884.412989496947,765.062067015664
STATISTICS_MINIMUM=4
STATISTICS_MEAN=226.07921779459
STATISTICS_MEDIAN=0
STATISTICS_MODE=0
STATISTICS_STDDEV=29.739081853631
COMPRESSION=RLE
Band 3 Block=64x64 Type=UInt16, ColorInterp=Undefined
Description = Layer_3
Minimum=0.000, Maximum=255.000, Mean=172.929, StdDev=27.135
NoData Value=256
Metadata:
STATISTICS_COVARIANCES=710.510646703791,765.062067015664,736.335138826829
STATISTICS_MEAN=172.92884721066
STATISTICS_MEDIAN=0
STATISTICS_MODE=0
STATISTICS_STDDEV=27.135495920046
COMPRESSION=RLE
Thanks,
Allan.
Allan Oware
Cell: +254 727 365820
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140714/a3f28bac/attachment.html>
