[gdal-dev] gdal installation, geopdf not recognized
Eli Adam eadam at co.lincoln.or.us
Mon Jul 14 12:03:31 PDT 2014
On Mon, Jul 14, 2014 at 11:17 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Eli,
> On Mon, 14. Jul 2014 at 10:40:08 -0700, Eli Adam wrote:
>> I got this error from OSGeo4W too.  The last two lines of this page,
>> http://trac.osgeo.org/osgeo4w/ticket/408, lists the mailing list and
>> ticket tracker.  You can ask or report this error there.  Searching
>> through trac for OSGeo4W, I found this which seems like it might be
>> similar, http://trac.osgeo.org/osgeo4w/ticket/408
> I can't reproduce that.  WI_Madison_West_20130722_TM_geo.pdf works fine
> with both the 32 and the 64bit build in OSGeo4W (using gdal-1.11.0-2).
I tried gdalinfo --debug on but that did not provide additional information.
gdalinfo --version  reports GDAL 1.11.0, released 2014/04/16
Before I try updating OSGeo4W and seeing if anything changes, is there
anything else to try to find the source of the error?  My install is
the result of an advanced install about three months ago and probably
updated about a month or two ago.
Thanks, Eli
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
