[gdal-dev] gdal2tiles.py alternative
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Tue Jul 15 09:51:20 PDT 2014
This might be of interest to users of gdal2tiles.py:
<https://github.com/geo-data/cesium-terrain-builder#ctb-tile>. Although
originally designed to create terrain tiles for the Cesium Javascript
engine, it
can also create tiles in any GDAL write enabled file based format e.g:
ctb-tile --output-format GTiff --profile mercator --output-dir ./tiles
./input-data.vrt
Apart from the case where you need tiles in formats other than PNG or
JPEG, it
might also be useful if you need more performance: the application is
multithreaded and a quick benchmark suggests that on a 1 core machine
you get a
3x speed increase and on a 4 core machine it is a 4x speed increase
(disk i/o
starts to be more limiting, it seems).
The tool also performs warping if the input data source is not in the output
grid projection.
If you have docker on your system then an easy way to get to a command
prompt
with `ctb-tile` available is to run:
docker run -t -i homme/cesium-terrain-builder:0.3.0 bash
Note you don't get the fancy KML or webviewer output that you do with
gdal2tiles!
The software heavily leverages GDAL, so thank you.
Homme
