[gdal-dev] GDAL Arbitrary Warp Problems
    Homme Zwaagstra
    hrz at geodata.soton.ac.uk
    Tue Jul 15 12:10:51 PDT 2014
Hi Michael,
I had to tangle with warping recently and took inspiration from both the warp tutorial and the gdalwarp source.  The result is at <https://github.com/geo-data/cesium-terrain-builder/blob/master/src/GDALTiler.cpp#L202> - it may be of help.
Homme
On 15 July 2014 20:00:50 GMT+01:00, Even Rouault <even.rouault at mines-paris.org> wrote:
>Le mardi 15 juillet 2014 20:52:16, Michael Aschenbeck a écrit :
>> Thanks for your response.
>> For my application, I will be creating the transformation on the fly.
> It
>> will be a non-standard transformation.  Unless I'm mistaken, I don't
>> believe this can be done with gdalwarp directly.
>> Also, I am under the assumption that its source code is introduced in
>the
>> tutorial I am working off of (http://www.gdal.org/warptut.html).
>Yet, this
>> just introduces a standard transformation, not a custom one.  This is
>why
>> I'm having trouble.
>When doing custom stuff, you often need to step into GDAL code to
>understand
>better how things are interacting together.
>Actually looking at your identityTransform and
>GDALSuggestedWarpOutput2(), I
>think there's at least something you should fix. You should initialize
>all the
>nPointcount elements of then panSuccess array to 1.
>Even
>Geospatial professional services
>http://even.rouault.free.fr/services.html
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140715/0e7ee03c/attachment.html>
