[gdal-dev] Rename and Reorder Layers?
Even Rouault even.rouault at mines-paris.org
Thu Jul 17 04:29:06 PDT 2014
Nik,
> I have two simple questions (not sure if the answers are as simple)...
> 1.  Is it possible to rename an OGR layer in place within a writeable data
> store without first creating a copy of the entire layer?
There's no provision in the OGR API to do that currently. Although it could be
nice to have. That would require of course updating the drivers that would
support that capability, and which are coded currently under the assumption that
the layer name is immutable.
For which driver(s) would you be interested to have that capability ?
> The only way I've found to do this is to use OGR_DS_CopyLayer() (or similar)
> and then delete the old layer which is fairly expensive as it has to copy all
> of the features as well.
For drivers that are related to SQL databases, issuing an "ALTER TABLE foo
RENAME TO bar" with ExecuteSQL(), and re-opening the datasource afterwards (OGR
will not notice the change) should do it.
> 2.  Is it possible to change the order of layers within a writeable OGR data
> store?  (Ie, change the ordering/indexing of layers as they would be
> retrieved with OGR_DS_GetLayer() ).
That would be much more involved, not to say impossible. For example, for SQL
based drivers, the driver list is issued from a request in system tables or
other tables and there's nothing to control the order of retrieval.
For filebased drivers, such as a directory of shapefiles, it depends on the
order of the operating system in which it return the filenames. Nothing you can
have control on.
To make it possible reliably would probably involve adding a special OGR
metadata table with (order_number, layer_name) columns.
A potential workaround is to use a OGR VRT file as a thin wrapper above your
"real" datasource. The layers will be ordered in the order they are listed in
the VRT.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
