[gdal-dev] GDAL 1.7.3 can't read tiff written by GDAL 1.11
Eli Adam
eadam at co.lincoln.or.us
Mon Jul 21 13:18:27 PDT 2014
Hi all,
I've got some recent tiff data that can't be read by GDAL 1.7.3
("gdalinfo.exe has stopped working"). It appears to work fine with
GDAL 1.11. The output from GDAL 1.11 can't be read by GDAL 1.7.3
either. Hmm, oddly it seems to work with GDAL 1.6.
I have an older MapServer and GDAL that I'd like to use with new data
without updating MapServer and GDAL so my goal is find a way to use or
alter the data so it is usable by GDAL 1.7.3. I also want to know if
the data is valid and complies with the the geotif specification.
This is on Windows 7 and OSGeo4W although I also had some similar
issues on Ubuntu 10.04. Below are GDAL 1.11 version, gdalinfo with
debug, listgeo, and finally gdal_translate output that can't be read
by GDAL 1.7.3 (attached). There are messages about "GTIFF: converting
geokey to meters to fix bug in old libgeotiff" and "TIFFReadDirectory:
Warning, Unknown field with tag 2457 (0x999) encountered." Further
below the GDAL1.11 information, is GDAL 1.7.3 showing that it can't be
read and the error output.
Do 06S08W19_gdal1_11_ouput2.tif and 06S08W19.tif conform to the geotif
specification and contain valid data? Any suggestions on how to keep
using my older install without updating?
Best regards, Eli
gdalinfo --version
GDAL 1.11.0, released 2014/04/16
gdalinfo 06S08W19.tif --debug on
GDAL: GDALOpen(06S08W19.tif, this=027C3F20) succeeds as GTiff.
Driver: GTiff/GeoTIFF
GDAL: GDALDefaultOverviews::OverviewScan()
Files: 06S08W19.tif
06S08W19.tfw
Size is 3314, 5508
GTIFF: converting geokey to meters to fix bug in old libgeotiff
Coordinate System is:
PROJCS["NAD_1983_2011_StatePlane_Oregon_North_FIPS_3601_Ft_Intl",
GEOGCS["GCS_NAD_1983_2011",
DATUM["NAD_1983_2011",
SPHEROID["GRS_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",44.33333333333334],
PARAMETER["standard_parallel_2",46],
PARAMETER["latitude_of_origin",43.66666666666666],
PARAMETER["central_meridian",-120.5],
PARAMETER["false_easting",8202099.737532808],
PARAMETER["false_northing",0],
UNIT["foot",0.3048,
AUTHORITY["EPSG","9002"]]]
Origin = (7367100.000000000000000,520508.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
TIFFTAG_XRESOLUTION=200
TIFFTAG_YRESOLUTION=200
Image Structure Metadata:
INTERLEAVE=PIXEL
OGRCT: PROJ >= 4.8.0 features enabled
OGRCT: Source: +proj=lcc +lat_1=44.33333333333334 +lat_2=46 +lat_0=43.6666666666
6666 +lon_0=-120.5 +x_0=2500000 +y_0=0 +ellps=GRS80 +units=ft +no_defs
OGRCT: Target: +proj=longlat +ellps=GRS80 +no_defs
Corner Coordinates:
Upper Left ( 7367100.000, 520508.000) (123d43'54.49"W, 45d 2'54.88"N)
Lower Left ( 7367100.000, 515000.000) (123d43'51.43"W, 45d 2' 0.54"N)
Upper Right ( 7370414.000, 520508.000) (123d43' 8.37"W, 45d 2'56.19"N)
Lower Right ( 7370414.000, 515000.000) (123d43' 5.31"W, 45d 2' 1.84"N)
Center ( 7368757.000, 517754.000) (123d43'29.90"W, 45d 2'28.36"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
GDAL: GDALClose(06S08W19.tif, this=027C3F20)
listgeo 06S08W19.tif
TIFFReadDirectory: Warning, Unknown field with tag 2457 (0x999) encountered.
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
7367100 520508 0
ModelPixelScaleTag (1,3):
1 1 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GTCitationGeoKey (Ascii,67): "PCS Name = NAD_1983_2011_StatePlane_Oregon_N
GeographicTypeGeoKey (Short,1): User-Defined
GeogCitationGeoKey (Ascii,92): "GCS Name = GCS_NAD_1983_2011
Datum = NAD_1
983_2011
Ellipsoid = GRS_1980
Primem = Greenwich
GeogGeodeticDatumGeoKey (Short,1): User-Defined
GeogAngularUnitsGeoKey (Short,1): Angular_Degree
GeogEllipsoidGeoKey (Short,1): User-Defined
GeogSemiMajorAxisGeoKey (Double,1): 6378137
GeogInvFlatteningGeoKey (Double,1): 298.257222101
GeogPrimeMeridianLongGeoKey (Double,1): 0
Unknown-3059 (Short,1): Unknown-1
ProjectedCSTypeGeoKey (Short,1): User-Defined
ProjectionGeoKey (Short,1): User-Defined
ProjCoordTransGeoKey (Short,1): CT_LambertConfConic_2SP
ProjLinearUnitsGeoKey (Short,1): Linear_Foot
ProjStdParallel1GeoKey (Double,1): 44.3333333333333
ProjStdParallel2GeoKey (Double,1): 46
ProjFalseOriginLongGeoKey (Double,1): -120.5
ProjFalseOriginLatGeoKey (Double,1): 43.6666666666667
ProjFalseOriginEastingGeoKey (Double,1): 8202099.73753281
ProjFalseOriginNorthingGeoKey (Double,1): 0
End_Of_Keys.
End_Of_Geotiff.
Projection Method: CT_LambertConfConic_2SP
ProjFalseOriginLatGeoKey: 43.666667 ( 43d40' 0.00"N)
ProjFalseOriginLongGeoKey: -120.500000 (120d30' 0.00"W)
ProjStdParallel1GeoKey: 44.333333 ( 44d20' 0.00"N)
ProjStdParallel2GeoKey: 46.000000 ( 46d 0' 0.00"N)
ProjFalseEastingGeoKey: 8202099.737533 m
ProjFalseNorthingGeoKey: 0.000000 m
Projection Linear Units: 9002/foot (0.304800m)
Corner Coordinates:
gdal_translate -projwin 7367110 520505 7367120 520495 06S08W19.tif
Input file size is 3314, 5508
Computed -srcwin 10 3 10 10 from projected window.
0...10...20...30...40...50...60...70...80...90...100 - done.
___________________________________________________________________________________________________
GDAL 1.7.3:
gdalinfo --version
GDAL 1.7.3, released 2010/11/10
original file:
Warning 1: TIFFReadDirectory:Unknown field with tag 2457 (0x999) encountered
GDAL: GDALOpen(06S08W19.tif, this=02A26878) succeeds as GTiff.
Files: 06S08W19.tif
06S08W19.tfw
Size is 3314, 5508
["gdalinfo.exe has stopped working" error message here]
GDAL 1.11 output:
gdalinfo 06S08W19_gdal1_11_ouput2.tif --debug on
GDAL: GDALOpen(06S08W19_gdal1_11_ouput2.tif, this=032C5840) succeeds as GTiff.
Files: 06S08W19_gdal1_11_ouput2.tif
Size is 10, 10
Here are the details from the gdalinfo.exe has stopped working message:
Problem signature:
Problem Event Name: APPCRASH
Application Name: gdalinfo.exe
Application Version: 0.0.0.0
Application Timestamp: 4cd807cc
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.22436
Fault Module Timestamp: 521eaa80
Exception Code: c0000005
Exception Offset: 0002e41b
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: d0cb
Additional Information 2: d0cbb85f3c4eb3a801a7e951e26036a7
Additional Information 3: 9027
Additional Information 4: 902705a348faa2357cb1e3c53c32a1b4
listgeo 06S08W19_gdal1_11_ouput2.tif
Version: 1
Key_Revision: 1.0
Tagged_Information:
0 0 0
7367110 520505 0
1 1 0
End_Of_Tags.
Keyed_Information:
GTCitationGeoKey (Ascii,56): "NAD_1983_2011_StatePlane_Oregon_North_FIPS_3
601_Ft_Intl"
GeogCitationGeoKey (Ascii,92): "GCS Name = GCS_NAD_1983_2011|Datum = NAD_1
983_2011|Ellipsoid = GRS_1980|Primem = Greenwich|"
End_Of_Keys.
End_Of_Geotiff.
Corner Coordinates:
Upper Left ( 7367110.000, 520505.000)
Lower Left ( 7367110.000, 520495.000)
Upper Right ( 7367120.000, 520505.000)
Lower Right ( 7367120.000, 520495.000)
Center ( 7367115.000, 520500.000)
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140721/55ef2907/attachment.tif>
