[gdal-dev] GeoPDF translation
Eli Adam eadam at co.lincoln.or.us
Wed Jul 23 18:37:11 PDT 2014
Hi rkologist,
The driver page [0] and a wiki page [1] indicate that you can crop to the
NEATLINE.
Jim, if you are still following this thread, you can edit the wiki page
with what you found works well for what you were doing too.
GDAL has really made the USGS new generation topos more accessible.
[0] http://www.gdal.org/frmt_pdf.html
[1] http://trac.osgeo.org/gdal/wiki/USGS_PDF_Topo
Best regards, Eli
On Wed, Jul 23, 2014 at 6:26 PM, rkologist <rcdemuth at indiana.edu> wrote:
> Can someone help me figure out where to insert the code to also have this
> crop to the neat line?  I need to tile several maps together, and it would
> really help.
> Thanks
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-GeoPDF-translation-tp3742508p5152932.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140723/a7a1792e/attachment.html>
