[gdal-dev] Upgrading Version Not Working
Nelson, Nicole
nelsonn at amazon.com
Thu Jul 24 14:21:52 PDT 2014
Even,
Is it possible that I am missing an external library? Do you know which
external libraries would be required to accomplish such a task?
Thanks,
Nicole
On 7/24/14, 1:03 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>Le jeudi 24 juillet 2014 21:49:19, Nelson, Nicole a écrit :
>> Hello,
>> I am working on an application which was developed by another
>>developer
>> about 2 years ago. At the time the developer used GDAL 1.9.1. I am
>>trying
>> to upgrade to the latest version of GDAL (1.11.0). However, I am not
>>able
>> to get the same functionality to work. I am reading in a shape file with
>> ogr.Open which is successful. Then I am able to get a layer
>>successfully.
>> On that layer I try to apply a spatial filter with a single point
>>geometry
>> representing a latitude and longitude pair. However, when I call
>> GetNextFeature I always get null, regardless of the input. The
>> GetNextFeature function previously returned at least one feature. Did
>> something change in the versions that I may have missed?
>Nicole,
>Single point spatial filter must be an odd use case. Not sure this is
>present
>in our regression tests, so that might have been accidentaly broken.
>However I
>just made an experiment with GDAL trunk :
>$ cat square.csv
>id,WKT
>1,"POLYGON((0 0,0 1,1 1,1 0,0 0))"
>$ ogr2ogr square.shp square.csv
>$ ogrinfo square.shp -al -spat 0.25 0.5 0.25 0.5
>INFO: Open of `square.shp'
> using driver `ESRI Shapefile' successful.
>Layer name: square
>Geometry: Polygon
>Feature Count: 1
>Extent: (0.000000, 0.000000) - (1.000000, 1.000000)
>Layer SRS WKT:
>(unknown)
>WKT: String (80.0)
>OGRFeature(square):0
> id (String) = 1
> WKT (String) = POLYGON((0 0,0 1,1 1,1 0,0 0))
> POLYGON ((0 0,0 1,1 1,1 0,0 0))
>So at least on that example it seems to work.
>> Is there
>> something that would make GetNextFeature return null, but GetFeature at
>> various indices return values?
>Yes, GetFeature() doesn't take into account the spatial filter.
>Best regards,
>Even
>Geospatial professional services
>http://even.rouault.free.fr/services.html
