[gdal-dev] creation of Geospatial PDF
Luca Delucchi
lucadeluge at gmail.com
Fri Jul 25 06:45:10 PDT 2014
On 25 July 2014 15:23, Even Rouault <even.rouault at mines-paris.org> wrote:
>> Hi all,
>> I would like to create a Geospatial PDF with several vectors, is it possible?
> That should be possible yes.
>> I tried with ogr2ogr but it failed,
> How ?
- first attempt
ogr2ogr -f PDF trentino.pdf zps_trento.shp grafo.shp
FAILURE: Couldn't fetch requested layer 'grafo.shp'!
- second attempt
ogr2ogr -f PDF -update trentino.pdf grafo.GeoJSON
- third attempt
ogr2ogr -f PDF trentino.pdf zps_trento.GeoJSON -lco OGR_DATASOURCE=grafo.GeoJSON
> reading the documentation I found
>> EXTRA_RASTERS to add several raster but not EXTRA_VECTORS. There is
>> OGR_DATASOURCE but the documentation say that it is used "to display
>> on top of the raster layer", and it doesn't work with OGR.
> Which version of GDAL are you using ?
1.11
> - If trunk, the relevant doc is : http://gdal.org/frmt_pdf.html
> - If 1.11 or older, http://gdal.org/1.11/frmt_pdf.html and
> http://gdal.org/1.11/ogr/drv_pdf.html
> But in both cases, ogr2ogr -f PDF the.pdf input_datasource should work
yes if I use only one vector datasource yes,but I'm not able to put
more then one vector in only one PDF
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
