[gdal-dev] GeoJSON coordinate values truncated to integers
Thomas Sevaldrud thomas at silentwings.no
Sat Jul 26 17:16:23 PDT 2014
Hi, I'm having a strange problem that appears to be related to the GeoJSON
driver in GDAL 1.11.0
When reading a polygon geometry in geographical lat/lon coordinates, all my
coordinate values are returned in integer degrees. When using ogrinfo it
dumps the coordinate values with correct decimals, so it must be something
I have done wrong... Here is the relevant code:
   OGRDataSource *ds = OGRSFDriverRegistrar::Open(filename_.c_str(), FALSE );
   int num_layers = ds->GetLayerCount();
   for(int i = 0; i < num_layers; i++)
      OGRLayer* layer = ds->GetLayer(i);
      layer->ResetReading();
      OGRFeature* feature;
      while((feature = layer->GetNextFeature()) != NULL)
         OGRGeometry* geometry = feature->GetGeometryRef();
         if(geometry == NULL)
            continue;
         int geom_type = wkbFlatten(geometry->getGeometryType());
         if(geom_type == wkbPolygon)
            OGRPolygon* ogr_poly = (OGRPolygon*)geometry;
            OGRLinearRing* ext_ring = ogr_poly->getExteriorRing();
            for(int j = 0; j < ext_ring->getNumPoints() - 1; j++)
               double x = ext_ring->getX(j);
               double y = ext_ring->getY(j);
Now, the x, and y values here are always truncated to integer values. This
does not happen with for example shp files.
Any ideas what I might have done wrong here?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140727/a4ae5cd6/attachment.html>
