[gdal-dev] GeoJSON coordinate values truncated to integers
Thomas Sevaldrud
thomas at silentwings.no
Sun Jul 27 15:07:33 PDT 2014
Ah, that fixed it! Thanks :-)
- Thomas
On Sun, Jul 27, 2014 at 1:57 PM, Dmitriy Baryshnikov <bishop.dev at gmail.com>
wrote:
> Hi,
> This is usually according to the locale. Try set "C" locale like this.
> cha* old_locale = setlocale(LC_NUMERIC, "C");
> before opening datasource
> and reset it back after reading all fetures
> setlocale(LC_NUMERIC, old_locale);
> This is not the solution (I fixed it here
> http://trac.osgeo.org/gdal/ticket/5461) but some kind of workaround.
> Best regards,
> Dmitry
> 27.07.2014 15:40, Thomas Sevaldrud пишет:
> (Sorry about the repost, I forgot the subject tag in the previous one..)
> Hi, I'm having a strange problem that appears to be related to the
> GeoJSON driver in GDAL 1.11.0
> When reading a polygon geometry in geographical lat/lon coordinates, all
> my coordinate values are returned in integer degrees. When using ogrinfo it
> dumps the coordinate values with correct decimals, so it must be something
> I have done wrong... Here is the relevant code:
> OGRDataSource *ds = OGRSFDriverRegistrar::Open(filename_.c_str(), FALSE );
> int num_layers = ds->GetLayerCount();
> for(int i = 0; i < num_layers; i++)
> OGRLayer* layer = ds->GetLayer(i);
> layer->ResetReading();
> OGRFeature* feature;
> while((feature = layer->GetNextFeature()) != NULL)
> OGRGeometry* geometry = feature->GetGeometryRef();
> if(geometry == NULL)
> continue;
> int geom_type = wkbFlatten(geometry->getGeometryType());
> if(geom_type == wkbPolygon)
> OGRPolygon* ogr_poly = (OGRPolygon*)geometry;
> OGRLinearRing* ext_ring = ogr_poly->getExteriorRing();
> for(int j = 0; j < ext_ring->getNumPoints() - 1; j++)
> double x = ext_ring->getX(j);
> double y = ext_ring->getY(j);
> Now, the x, and y values here are always truncated to integer values.
> This does not happen with for example shp files.
> Any ideas what I might have done wrong here?
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140728/e460a552/attachment.html>
