[gdal-dev] Does gdal_calc.py not calculate arithmetic with in the same file?
Etienne Tourigny etourigny.dev at gmail.com
Tue Jul 29 06:37:18 PDT 2014
I am not sure, but you can do the following to make sure:
cp infile infile2
gdal_calc.py -A infile --A_band 1 -B infile2 --B_band 0 --outfile outfile
--calc "(A-B)/(A+B)"
Also, perhaps the extra comma in your command might be to blame "-B infile,"
Etienne
On Tue, Jul 29, 2014 at 3:46 AM, Cleo Drakos <cleo21drakos at gmail.com> wrote:
> Hi GDAL Developers,
> I have one GeoTIFF file with 2 bands. The data type is Byte. I want to
> calculate (Band2-Band1)/(Band2+Band1).
> But the following command provided a dark image:
> gdal_calc.py -A infile --A_band 1 -B infile, --B_band 0 --outfile outfile
> Thanks for your time.
> cleo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140729/5d7b8e69/attachment.html>
