[gdal-dev] The documentation should be corrected, I think.
Cleo Drakos
cleo21drakos at gmail.com
Tue Jul 29 20:54:48 PDT 2014
Dear all:
The problem I was facing has been solved. I detected that the problem was
with the band number '0'. Solution is: the band number starts from '1'.
But, the gdal documentation says that the default band number is '0'.
http://www.gdal.org/gdal_calc.html
The default band number is '1'.
Thanks.
cleo
On Wed, Jul 30, 2014 at 11:15 AM, Jeremy Palmer <JPalmer at linz.govt.nz>
wrote:
> Hi Cleo,
> Just been dealing with this type of issue.
> It’s likely that the byte datatype is overflowing.
> Try something like:
> --calc "(A.astype(int)-B.astype(int))/(A.astype(int)+B.astype(int))"
> Actually you might only need to cast one of the bands from byte to int, so
> the syntax could be:
> --calc "(A.astype(int)-B A.astype(int)+B)"
> Cheers
> Jeremy
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Cleo Drakos
> *Sent:* Wednesday, 30 July 2014 2:06 p.m.
> *To:* Vincent Schut
> *Cc:* gdal-dev
> *Subject:* Re: [gdal-dev] Does gdal_calc.py not calculate arithmetic with
> in the same file?
> Even if I converted the input file into Float 32 at first, the resulted
> image is still totally black.
> cleo
> On Tue, Jul 29, 2014 at 11:20 PM, Vincent Schut <schut at sarvision.nl>
> wrote:
> On 07/29/2014 04:04 PM, Cleo Drakos wrote:
> Thanks for your response.
> I tried the followings:
> gcalc = 'C:\\Users\\cleo\\Documents\\gdalpys\\gdal_calc.py'
> ##I produced second file (b)as the copy of first(a)
> a = 'D:\\a.tif'
> b = 'D:\\b.tif'
> outfile = 'D:\\result.tif'
> expr = '(A-B)/(A+B)'
> subprocess.call([sys.executable,gcalc,'-A',a,'--A_band','1','-B',b,'--B_band','0','--outfile',outfile,\
> '--calc',expr,'--type','Float32','--format','ENVI'],shell=True)
> a,b,outfile = None, None,None
> Unfortunately, resulted file is completely black.
> I hope someone can help me.
> I don't use gdal_calc myself, but I suppose the problem is the byte
> datatype. I would try to convert the input data to float32 first (use
> gdal_translate -ot Float32) and try again.
> Best,
> Vincent.
> On Tue, Jul 29, 2014 at 10:37 PM, Etienne Tourigny <
> etourigny.dev at gmail.com> wrote:
> I am not sure, but you can do the following to make sure:
> cp infile infile2
> gdal_calc.py -A infile --A_band 1 -B infile2 --B_band 0 --outfile outfile
> --calc "(A-B)/(A+B)"
> Also, perhaps the extra comma in your command might be to blame "-B
> infile,"
> Etienne
> On Tue, Jul 29, 2014 at 3:46 AM, Cleo Drakos <cleo21drakos at gmail.com>
> wrote:
> Hi GDAL Developers,
> I have one GeoTIFF file with 2 bands. The data type is Byte. I want to
> calculate (Band2-Band1)/(Band2+Band1).
> But the following command provided a dark image:
> gdal_calc.py -A infile --A_band 1 -B infile, --B_band 0 --outfile outfile
> Does gdal_calc.py not calculate arithmetic with in the same file?
> Thanks for your time.
> cleo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140730/1c7b0cf9/attachment.html>
