[gdal-dev] Problem with BIL files and GDAL
Belén
beln1 at hotmail.com
Wed Jul 30 04:23:14 PDT 2014
Hi again,
I tried yesterday the option "-ot UInt16" but the result was the same.
This is the result os executing "gdalinfo -stats":
Driver: EHdr/ESRI .hdr Labelled
Files: prueba.bil
prueba.hdr
prueba.stx
Size is 4000, 4000
Coordinate System is `'
Origin = (504815.000000000000000,4766395.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Corner Coordinates:
Upper Left ( 504815.000, 4766395.000)
Lower Left ( 504815.000, 4726395.000)
Upper Right ( 544815.000, 4766395.000)
Lower Right ( 544815.000, 4726395.000)
Center ( 524815.000, 4746395.000)
Band 1 Block=4000x1 Type=UInt16, ColorInterp=Undefined
Min=87.000 Max=263.000
Minimum=87.000, Maximum=263.000, Mean=220.726, StdDev=23.721
You gave me a great idea, I think PNG supports UInt16 but I'v tried using -ot BYTE and it works.
Thanks you very very much for your help. You saved my life!!
Regards.
Belén Muñoz.
Date: Wed, 30 Jul 2014 12:58:44 +0200
Subject: Re: [gdal-dev] Problem with BIL files and GDAL
To: beln1 at hotmail.com
CC: gdal-dev at lists.osgeo.org
Since we are here, you could re-run gdalinfo -stats on your dataset. (Maybe you see a black image due to a dynamic concentrated on low values).
Moreover you may consider using the "-scale" option on gdal_translate to scale your values to byte or make sure to preserve the output type with the option "-OT UInt16".
Honestly, I don't remember if PNG support 16 bits (But would say "yes") and if the tool/browser/what else you will use to open it will show you correctly.
Hope this helps.
Regards,
Daniele
http://goo.gl/NWWaa2 for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
On Wed, Jul 30, 2014 at 12:26 PM, Belén <beln1 at hotmail.com> wrote:
Hi Daniele,
Thank you for your answer.
This is the output of gdalinfo:
Files: prueba.bil
prueba.hdr
Size is 4000, 4000
Corner Coordinates:
Thank you again!!
Regards.
Belén Muñoz.
Date: Wed, 30 Jul 2014 12:20:09 +0200
could you run a gdalinfo on your origin file and provide us the output?
Wondering if its datatype is float and a straight gdal_translate (without scaling applied) truncate all values when going to Byte PNG.
Cheers,
Daniele
GeoSolutions S.A.S.
Italy
On Wed, Jul 30, 2014 at 11:22 AM, Belén <beln1 at hotmail.com> wrote:
Hello!
My name is Belén and i'm trying to convert a .bil file (.bil and .hdr) to a .png using gdal_translate, it seems to work fine, there are no error messages but when I open the .png file, I only have a big completely black square.
There's some special thing I should be doing? I'd appreciate any help, because I'm completely lost.
Thank you very much in advance.
Regards.
Belén Muñoz.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140730/009e0399/attachment.html>
