[gdal-dev] Problem with .asc files
00darki
alex.jong0019 at gmail.com
Wed Jul 30 05:23:55 PDT 2014
Hi everyone !
I've a problem with gdal, it doesn't recognise my files with .asc
extensions.
*>gdalinfo N42W00.asc
ERROR 4: 'N42W00.asc' not recognised as a supported file format.
gdalinfo failed - unable to open 'N42W00.asc'.*
However, the gdal driver is presnt :
*>gdalinfo --formats | find "ASC"
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
GSAG (rwv): Golden Software ASCII Grid (.grd)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
XYZ (rwv): ASCII Gridded XYZ*
And this files are well formated :
*W:12.000000 E:13.000000 S:38.000000 N:39.000000 grid:1.000000
cols:61 rows:61 endian:10203 min:-10.000000 max:3211.000244
2381.00 2391.00 2416.00 2450.00 2498.00 2537.00 2560.00 2579.00 2557.00
2404.00
2273.00 2208.00 2164.00 2214.00 2210.00 2242.00 2292.00 2329.00 2362.00
2378.00
Thank you for any help ;)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-asc-files-tp5154189.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
