[gdal-dev] A problem with Alaska State Plane Zone 1 and ogr2ogr
Jay Cable jay at alaska.edu
Fri Jun 6 18:18:52 PDT 2014
Fantastic!  Adding the the "+wktext" argument makes ogr2ogr generate the
values I was expecting.  I will rebuild my copy of gdal with the fixes in
the ticked mentioned.
Thanks again,
  -Jay
- Jay Cable - jay at alaska.edu - (907)474-1856 -
- Geographic Information Network of Alaska -  University of Alaska  -
On Fri, Jun 6, 2014 at 11:18 AM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Jay,
> I've reproduced and fixed your issue. See
> http://trac.osgeo.org/gdal/ticket/5511 for details
> An easy workaround is to add " +wktext" at the end of your proj.4 string.
> This
> will instruct the GDAL SpatialReference engine to keep literaly your proj.4
> string to use it later. Otherwise the original proj.4 is converted into WKT
> and not preserved, so when needed it afterwards, GDAL rebuilds it from WKT.
> Best regards,
> Even
> > Hello,
> > Please forgive me if this is the wrong place for this question, but  I am
> > trying to use Alaska State Plane Zone 1 with ogr2ogr, and can't seem to
> get
> > it to project the data correctly.  I am probably doing something wrong,
> but
> > can't seem to figure it out.   I am pretty sure that my projection string
> > is correct, as the results from proj match what the NGS's online
> calculator
> > gives.
> > When I use ogr2ogr like this:
> > ogr2ogr -t_srs "+proj=omerc +lat_0=57 +lonc=-133.6666666666667
> > +alpha=-36.86989764583333 +k=0.9999 +x_0=5000000 +y_0=-5000000 +no_uoff
> > +datum=NAD83 +units=m +no_defs" akzone1.zhp point.84.shp
> > On a shapefile with a single point  - POINT (-131.811033901222117
> > 55.409950489560302)
> > I get:
> > POINT (4988757.639998742379248 -5210867.590697132050991)
> > What I get from a shape file reprojected with ESRI products is:
> > POINT (936203.399999997578561 399658.200000001117587)
> > I believe the ESRI result is correct, as it matches the the NGA online
> > converter.
> > Proj also generates the correct value:
> > Jays-MacBook-Air-2:zone1 Jay$ proj +proj=omerc +lat_0=57
> > +lonc=-133.6666666666667 +alpha=-36.86989764583333 +k=0.9999 +x_0=5000000
> > +y_0=-5000000 +no_uoff +datum=NAD83 +units=m +no_defs
> > -131.811033901222117 55.409950489560302
> > 936203.40    399658.20
> > So, my question is what am I missing to make the results from ogr2ogr
> match
> > up with proj?
> > My thanks,
> >  -Jay Cable
> > Rel. 4.8.0, 6 March 2012
> > usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
> > Jays-MacBook-Air-2:zone1 Jay$ ogr2ogr --version
> > GDAL 1.11.0, released 2014/04/16
> > Oh,  the online NGS converter I mentioned:
> > http://www.ngs.noaa.gov/cgi-bin/spc_getpc.prl
> >            Latitude           Longitude      Datum Zone
> >  INPUT =   N552435.8217       W1314839.7220  NAD83 5001
> >   NORTH(Y)    EAST(X)     AREA  CONVERGENCE   SCALE
> >   METERS      METERS            DD MM SS.ss
> >   399658.198  936203.401  AK 1   1 32 38.22   0.99990159
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140606/572ebc7c/attachment.html>
