[gdal-dev] Using GDAL with gridded XYZ that has no 'nodata' values?
Sam Franklin
mailinglist.samfranklin at gmail.com
Sat Jun 7 13:31:09 PDT 2014
Hey Even - me again on this xyz sorting issue.
I've got a new xyz file that it is not recognised by gdal even after using
the sort command you provided earlier in the thread.
The problem xyz is here |
https://dl.dropboxusercontent.com/u/4086367/001-1.xyz.zip
The error is:
ERROR 1: Ungridded dataset: At line 363, X is 568509.090000, where as
568514.090000 was expected (1)
gdalinfo failed - unable to open '001-1.xyz'.
GDAL seems to fail at the start of a new row of data?
I've tried various descend/ascend combinations of the columns = no joy.
I'm running GDAL 1.11.0 on OSX 10.9.3.
Any ideas? Thanks again in advance for any help! Very much appreciated.
Cheers
Sam
On 27 May 2014 14:09, Sam Franklin <mailinglist.samfranklin at gmail.com>
wrote:
> Hi Even. Great, that worked for me too when sorting on both columns.
> Really appreciate you help.
> Sam
> On 27 May 2014 01:31, Even Rouault <even.rouault at mines-paris.org> wrote:
>> Le mardi 27 mai 2014 00:06:33, Sam Franklin a écrit :
>> > Hey Even - great tip. The sort command you suggested worked well with
>> that
>> > xyz dataset.
>> > However, I've found a further dataset that does not work with gdal even
>> > after the sort. This is the error:
>> > mbp-sf:data08 samfranklin$ gdal_translate data08-02-sorted.xyz
>> > data08-02.tif
>> > Input file size is 4371, 11210
>> > 0...10...20...30...40.ERROR 1: At line 1100207, found 48162.000000
>> instead
>> > of 48164.000000 for nBlockYOff = 4951ERROR 1: data08-02-sorted.xyz,
>> band 1:
>> > IReadBlock failed at X offset 0, Y offset 4951
>> > ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 4951
>> > See screenshot below, the data is arranged into three 'strips'. See
>> dropbox
>> > link to the data |
>> > https://dl.dropboxusercontent.com/u/4086367/data08-02.xyz.zip
>> > Any workaround you can think of?
>> Probably an issue with just sorting on column 2. I didn't have the same
>> error
>> as you, but anyway you should try :
>> sort -nk 2 -nk 1 data08-02.xyz > data08-02-sorted.xyz
>> with that I manage to translate the file.
>> Geospatial professional services
>> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140607/213eafc6/attachment.html>
