[gdal-dev] Using GDAL with gridded XYZ that has no 'nodata' values?
Even Rouault even.rouault at mines-paris.org
Sun Jun 8 07:43:34 PDT 2014
Le dimanche 08 juin 2014 15:04:31, Sam Franklin a écrit :
> Even - okay thanks for taking a look, I'll check out the 2.0dev version as
> you mentioned.
Sam,
I meant that the 2.0dev has some improvements, but they are not sufficient to
read that file.
Even
> Cheers
> S
> On 7 June 2014 21:59, Even Rouault <even.rouault at mines-paris.org> wrote:
> > Le samedi 07 juin 2014 22:31:09, Sam Franklin a écrit :
> > > Hey Even - me again on this xyz sorting issue.
> > > I've got a new xyz file that it is not recognised by gdal even after
> > using
> > > the sort command you provided earlier in the thread.
> > > The problem xyz is here |
> > > https://dl.dropboxusercontent.com/u/4086367/001-1.xyz.zip
> > > The error is:
> > >  ERROR 1: Ungridded dataset: At line 363, X is 568509.090000, where as
> > > 568514.090000 was expected (1)
> > >  gdalinfo failed - unable to open '001-1.xyz'.
> > > GDAL seems to fail at the start of a new row of data?
> > > I've tried various descend/ascend combinations of the columns = no joy.
> > > I'm running GDAL 1.11.0 on OSX 10.9.3.
> > > Any ideas?  Thanks again in advance for any help! Very much
> > > appreciated.
> > The development version 2.0dev has improvements over 1.11 that would help
> > a bit, but this file would still require additional developments since
> > the spacing between horizontal or vertical coordinates isn't constant
> > due to rounding to 2 decimal figures. Some tolerance should be added to
> > the driver to
> > support it.
> > > Cheers
> > > Sam
> > > On 27 May 2014 14:09, Sam Franklin <mailinglist.samfranklin at gmail.com>
> > > wrote:
> > > > Hi Even. Great, that worked for me too when sorting on both columns.
> > > > Really appreciate you help.
> > > > Sam
> > > > On 27 May 2014 01:31, Even Rouault <even.rouault at mines-paris.org>
> > wrote:
> > > >> Le mardi 27 mai 2014 00:06:33, Sam Franklin a écrit :
> > > >> > Hey Even - great tip.  The sort command you suggested worked well
> > with
> > > >> that
> > > >> > xyz dataset.
> > > >> > However, I've found a further dataset that does not work with gdal
> > > >> > even after the sort. This is the error:
> > > >> > mbp-sf:data08 samfranklin$ gdal_translate data08-02-sorted.xyz
> > > >> > data08-02.tif
> > > >> > Input file size is 4371, 11210
> > > >> > 0...10...20...30...40.ERROR 1: At line 1100207, found 48162.000000
> > > >> instead
> > > >> > of 48164.000000 for nBlockYOff = 4951ERROR 1:
> > > >> > data08-02-sorted.xyz,
> > > >> band 1:
> > > >> > IReadBlock failed at X offset 0, Y offset 4951
> > > >> > ERROR 1: GetBlockRef failed at X block offset 0, Y block offset
> > > >> > 4951
> > > >> > See screenshot below, the data is arranged into three 'strips'.
> > > >> > See
> > > >> dropbox
> > > >> > link to the data |
> > > >> > https://dl.dropboxusercontent.com/u/4086367/data08-02.xyz.zip
> > > >> > Any workaround you can think of?
> > > >> Probably an issue with just sorting on column 2. I didn't have the
> > same
> > > >> error
> > > >> as you, but anyway you should try :
> > > >> sort -nk 2 -nk 1 data08-02.xyz > data08-02-sorted.xyz
> > > >> with that I manage to translate the file.
> > > >> Geospatial professional services
> > > >> http://even.rouault.free.fr/services.html
